looking for carb for Shop Force AT 04103 generator
ttimtucker
  • / looking for carb for Shop Force AT 04103 generator
I checked the governor springs as per the link you posted and all looks good. I will attempt to reset the governor next. If that does not correct the problem I will create a support ticket on the Generator Gurus site. Thanks!
You need a tachometer to properly set governed top speed. Need to check at both load and no load conditions. Can’t just go by spring location. I should add that if you find that the RPMs are off and you adjust the carb to specs, you should also check the voltage and hertz output. If these are out of specs you could easily burn out equipment or tools.
or maybe it will take opening up the main jet a little more than a frog hair.
sgkent
I would use the choke, or something to substitute and richen the mixture with the choke to see if that stopped the surging. That will tell you if it is running too lean. You can cut the fuel off and let it die from starvation to see if it is too rich. If the rpm gets better when the mixture changes then you will know it is a mixture issue. If the mixture does not improve then you will know that it is not the carb. Sometimes the placement of the spring can make it more or less sensitive to surges. Also you can hold the throttle steady by hand and see if it runs steady. That will also tell you if the carb is metering fuel properly, and the governor is at fault. I've seen engines run lean also because the fuel flow into the carb is poor due to the filter or filter sock being plugged.
