djdicetn
- Sep 3, 2012
- 12
- 2,193
Have you considered a ztr (zero turn riding mower)? They can be had under 3k and with proper maintenance will last a long time. Plus be much more efficient at doing exactly what your primary purpose is!! Mowing. Toro , cub cadet , snapper , et all... have good decent mower in a 42 inch deck which will last you 10 years or more and be fun to use. My entry level snapper lasted 12 years before I even had to replace a belt!! granted the avg price for that class of mower is around $2700 , fully 1k more than your budget. It will be worth it though in time saved and how well it cuts. That being said, if the $1700 limit is a hard one, given the above comment about proper maint, any rider in the price range will last you a long time as well. Also I have had much better luck with beltlife of mowers that used electric pto's to engage the blades than the old pull a lever versions. Dont know if the pto is easier on the bladebelt or if it just comes on better quality mowers. By the way when I told my wife I was buying a $2700 mower she said not no but h3ll no! 2 weeks after I bought it ... she told me it was the best purchase I had ever made.
DPuro329,
I can't agree with user txzrider on what you can get into a decent entry-level Zero Turn for that is of any quality. You may find one in the price range he mentioned in a big box retailer like the Toro Timecutter or the Husqvarna RZ series but neither of those would have the durability of that YT42XLS lawn tractor. A "decent" Husqvarna ZTR(the RZ4222F), which at least has a fabricated deck, instead of a stamped deck has an MSRP of $3399 and has the sealed HydroGear trannies. You won't find the RZ422F at Lowes or Home Depot, just at the dealer. You may find a Dixie Chopper Zee 1 for $2,900 but it has the Briggs Intek which I would advise against. The Zee 2 will run you $3800 and has the Kawasaki engine which would do you well. IMHO, you will need to spend between $3500-$4000 to get a Zero Turn that is worth spending several thousand dollars on for durability & reliability. You can get one cheaper than the $5k-$6k mentioned earlier and if I were recommending a good Zero Turn in the price range I gave you it would be the Toro Titan ZX4820 which is a VERY good entry-level residential ZTR. If I were to recommend a higher quality ZTR(because I own a Gravely and can attest to their quality first-hand), a 44" ZT HD residential(with many commercial-grade features) has an MSRP of $4899 and would be closer to that $5k that you obviously were not interested in investing in a mower.
