Mower deck Looking for a used gearbox for a Kubota ZD21 60 inch pro deck
jthorne
I have a Kubota ZD21 zero turn mower with a 60 inch pro deck. The gearbox has gone out and I am desperately looking for a used replacement gearbox. If anyone knows where I might find one please drop me an email at [email protected].
Regards,
Jim Thorne
Hello Jim & WELCOME to LMF...
If you have not broken the housing on the gear box... they are rebuild-able.
If you have to replace the complete gearbox you should take a few measurements, mounting, gear ratio & input direction vs output... Then check other models And manufacturers deck gearboxes ... There will be a lot of other decks using the same gearbox.... Kubota & most others don't build their own gearboxes... :smile:KennyV
Regards,
Jim Thorne
I'm also looking for a gear box for a D782 if you can help me. Drop me a line at bertieverret@ Tpsd.org
