I have an 80's GT6000 lawn tractor, Kohler Command 18HP v twin, hydrostatic transmission.  The mount that holds the guide pulleys for the trans axle is damaged, this mounts directly to the transaxle and takes the belt from horizontal to vertical.  I am looking to replace the assembly. It was damaged (bent) when a belt broke and wrapped itself around it.  Does anyone have a unit they are parting out. I really would like to get all the bits that guide the drive belt assembly. The unit currently runs well, but eats drive belts every 8 to 10 hours of use.  The tractor runs really strong, has been in use by my family since new. I hope I can keep it alive a good bit longer.
Thanks
Brian
			Thanks
Brian
