Looking for a good cross-reference chart for aftermarket blades
NicholasEdwards70
Hey everyone, I'm trying to track down some alternative blades for my older Toro zero turn because the factory ones are getting way too expensive this season. I've been trying to find a solid cross-reference guide online but everything I find is either outdated or doesn't include the center hole dimensions. Does anyone happen to have a master list replacement mower blades guide or a link to a good compatibility chart that shows which aftermarket brands fit specific OEM deck sizes? I just want to find some decent heavy-duty mulching blades without having to blindly guess if they'll mount up correctly. Let me know what resources you guys use to match up your aftermarket parts!
You can go to the websites of Rotary, Oregon, or Stens. Put in your Toro part number and get several aftermarket alternatives. The blades length, width, thickness, and center hole diameter are listed for each particular blade.
Deck size will not always get you the correct blade.
What is the Toro part number for your OE blades?
Posting the model number won't hurt either.
Plus you got remember the OEM and others are dealing with increased metal tariffs [taxes] that they are passing along.
