(Account Closed)
- Dec 3, 2018
- 260
Ok - I just saw a video on youtube of someone pulling off the flywheel. and low and behold there was the green wire!. But it was connected to a small plastic rectangle.
I would like to order the whole part including the plastic rectangle if some knows the part number please and thank you to all for all your help,:thumbsup:
Page 61 (in the manual already posted), shows the BRAKE ASSEMBLY (BRAKE pad is INSIDE the flywheel).
The other end of the kill wire connects there, to the square piece.
As long as the engine stops when it should, there's NO reason to replace it. It's a simple piece of plastic and "springy retainer" that holds the wire in place.
When the engine kill bar is released, the mechanism shorts out that wire (killing the ignition, the internal((to the flywheel)) ), is spring loaded, pops out and stops the engine from rotating quickly (for safety).
As noted earlier, if the engine turns off immediately, stops spinning quickly, the mechanism/wire is fine. Don't mess with it, no reason to...
Might degrease the engine before buttoning up...
