Little help with Carb rebuild kit please
guitarsnlikker
Hi, I have Troy Bilt Pony 42inch mower with B&S engine:
Model 31C707
Type 0603 B2
Code 080812ZD
What is the proper Nikki carburetor rebuild kit?
Thank you,
6strings and a bottle!
Part number 796184
Really if the you don't damage the paper gasket or need the float needle, all you need is the bowl gasket set. I see no point myself in replacing good parts when 99% of the time it is the bowl gasket set that is all that is needed to be replaced and the rest of the gaskets are fine.
