LibertyZ hydro
The easiest way to get a Hydro Gear 55752 fitting, hose, pump, and 15W50 synthetic oil. Install the fitting and pump oil until comes out the over flow port on the fitting.
It requires only removing the #2 fitting plug in the following diagram on each hydro; otherwise, it likely you would need to remove each hydro to check the fluid level.
