jemilsch
- Jul 22, 2024
- 4
Hi folks. I have the LGT2654 with the Kohler Courage 26hp engine. My voltage (when running) is not getting any higher than 12.5 volts across the two battery terminals. Here are some things I have performed:
Is there an obvious issue that stands out? I almost feel like the repairs I have done (except the battery) were almost wastes of money as the conditions really haven't changed. Anyway I am puzzled and just don't know where to start on this. Could my springs be old/worn out on the carb to the point that the motor isn't spinning faster (faster spin = higher voltage output)? Maybe that's why it is surging a bit? I'd be willing to replace the carb but again I hate throwing money at the wrong solution if it will continue performing the same. Thanks for anyone's help!!
- Bought a brand new battery from Rural King
- Replaced both ignition coils
- Replaced voltage regulator
- Replaced alternator
- While removing the flywheel I noticed that 3 magnets were loose, so I epoxied those back on in the proper polarity.
