- Feb 19, 2020
- 114
- 12,421
One those appears to Brown. If so it come off the light switch and goes to the headlamps. Ignition switch mus in the run position and light switch on to test for 12v.
Also if the clicking is not the starter solenoid then it is either the fuel solenoid on the carb or the PTO clutch. Check and make to the PTO switch is off. Plus the brake/clutch must be fully depessed.
