Level deck on TB 30
zacher1950
Front to back ok. Side to side off by 1/2 inch. Nobody knows how to level it. Cut grass is terracing. Need help on leveling deck
mechanic mark
Scroll down page & click on manuals after clicking above website for Troy Bilt.
Click on second Download & see Deck page 17 middle column & follow instructions for leveling deck.
zacher1950
Front to back adjustment is good. Left side of deck is 1/2 inch higher than right side. Need to level but no one knows how. No side to side adjustment for the 30 inch mower
mechanic mark
Are you checking on level ground with tires aired up to specs. in Manual? If answer is yes then study deck visually from both sides, you may have to think of way of lowering left side deck mounting or raising right side of deck. Let us know how it goes, thanks, Mark
zacher1950
Tires are up to specs. I might try putting a rock on high side to adjust deck to level on both sides
