Left rear wheel falls off / Toro SR-21S Super recycling mower/ Direct drive/ Model 20042
W1D2C
  • / Left rear wheel falls off / Toro SR-21S Super recycling mower/ Direct drive/ Model 20042
Just finished and cut lawn. All good. Used rear tires (old ones worn), new bushings for each tire (2 per tire), new spacers since one was missing on rear tires. Replaced all tire bolts. Replaced oil tube bolt since was missing and tube loose. Greased with NLGI #2 lithium grease per Toro. Parts were not that expensive but sometimes hard to find.
May buy pivot arm for front since loose when moving front tires side to side (original pivot arm). Don't think can be rebuilt.
Smokes a little but need to retorque the bolts on head since at one time or another accidentally removed the two top bolts thinking it was for the cover (advice from here). Then go from there.
