leaking oil on 22 inch self propeled Toro mower
jmithell
Go to page two of the website and find illustration number 524, which is the seal on the oil fill tube. It is Briggs part number 692296. This is what I feel is the cause of your oil leak, replace it.
Sorry but I am not familiar with what website you are referring to? How do I find page 2 and how do I find the part numbers? Is this part of this website or a toro site?
Sorry, but I can't help you. Suggest you take it to the repair shop and have them replace the oil fill tube seal. That's my best and cheapest answer.
sanibel
have exact problem, model, symptoms, etc. Will replace the seal and let you know.
sanibel
was not seal. Was the main gasket between engine and its cover. used a gasket making material and worked like a charm
