Mwh0428 Well-Known Member Joined Dec 19, 2011 Messages 164 Feb 28, 2012 #11 What of you accidentally drilled a whole in the top of your gas tank should have to worry about that one?
reynoldston Lawn Pro Joined May 23, 2011 Messages 5,705 Feb 28, 2012 #12 Mwh0428 said: What of you accidentally drilled a whole in the top of your gas tank should have to worry about that one? Click to expand... If it a big hole make a patch frist and then use the JB weld. Just make sure everything is good and clean.
