Leaf blowers are genuinely useful once you learn how to work with them rather than against them. The key is directing debris toward a collection point before you start — otherwise yeah, you're just chasing leaves in circles.
A few tips that make them worth the investment:
- Use the blower to push clippings and debris off beds and hard edges first, then corral everything into a single pile
- For lawn cleanup, a backpack or mid-range handheld with decent CFM (around 400+) makes a big difference over the lightweight cheap ones
- Vacuum/mulch mode is underrated — shredding leaves 10:1 before bagging saves a ton of trips to the compost pile
If you're still deciding on a model, I went through a pretty detailed breakdown of current options — covers the balance of CFM, weight, and battery life that tends to matter most for regular yard use:
best leaf blower comparison guide
Once you get the technique down, going back to a rake feels like a step backwards.
