Leaf Blower?
I have an acre of grass and 500 trees and shrubs. But I am rural, I use the blower when the wind is strong to blow the leaves down the road.
Leaf blowers are genuinely useful once you learn how to work with them rather than against them. The key is directing debris toward a collection point before you start — otherwise yeah, you're just chasing leaves in circles.
A few tips that make them worth the investment:
- Use the blower to push clippings and debris off beds and hard edges first, then corral everything into a single pile
- For lawn cleanup, a backpack or mid-range handheld with decent CFM (around 400+) makes a big difference over the lightweight cheap ones
- Vacuum/mulch mode is underrated — shredding leaves 10:1 before bagging saves a ton of trips to the compost pile
If you're still deciding on a model, I went through a pretty detailed breakdown of current options — covers the balance of CFM, weight, and battery life that tends to matter most for regular yard use: best leaf blower comparison guide
Once you get the technique down, going back to a rake feels like a step backwards.
You going to blow them into the next county?
That's the plan. No, I live on a county road and the leaves and tumble weeds blow across open grasslands. The tumble weeds come from open grasslands and hang up in my trees. I just move them along. I am talking tumble weeds in the hundreds. These things are big, two feet in diameter or more and can't be broken down. The leaves are minor.
