Engine is on a Toro leaf blower. Two cycle engine starts right up with choke engaged but dies with-in seconds if choke is opened. Can keep it going by closing choke for an instant then opening choke half-way. What I've done so far: (1) replaced fuel lines, (2) replaced tank fuel filter, (3) removed carb, disassembled and ran thru sonic cleaner, then blew out orifices with compressed air (4) drained fuel and refilled tank with pretty heavy dose of carb cleaner, (5) new spark plug. Primer bulb doesn't leak and works well. No sign of fuel leakage. Air filter is clean. Injecting fuel into the carb with the primer bulb when engine starts to stall does not help. All I can think of is that I wasn't able to remove the carb's little wire mesh filter but it passed air readily enough (I think). Figure a carb re-build kit is in order but I'd sure appreciate any suggestions. Thanks- Al
