What coil would you suggest to replace an original 682337.
S steveleb Member Joined Oct 27, 2013 Threads 8 Messages 28 Sep 22, 2023 / LB 7268 Coil #1 What coil would you suggest to replace an original 682337.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,769 Sep 22, 2023 / LB 7268 Coil #2 Please post the units serial number, as I’m coming up with a different part number.
S steveleb Member Joined Oct 27, 2013 Threads 8 Messages 28 Sep 22, 2023 / LB 7268 Coil #3 Thats the numbe on the coil. Serial #8906752
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,769 Sep 23, 2023 / LB 7268 Coil #4 You are looking for a replacement, so I’m looking for the serial number?
S steveleb Member Joined Oct 27, 2013 Threads 8 Messages 28 Sep 23, 2023 / LB 7268 Coil #5 Are you looking for the serial number of the coil or the mower it self? Both are in my reply yesterday. Serial #8906752
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,769 Sep 23, 2023 / LB 7268 Coil #6 Original coil was 681578, superseded to a 100-2949.
S steveleb Member Joined Oct 27, 2013 Threads 8 Messages 28 Sep 23, 2023 / LB 7268 Coil #7 Sorry that one doesn't look like that would fit. Attachments 20230923_111521.jpg 466.2 KB · Views: 10
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,769 Sep 23, 2023 / LB 7268 Coil #8 Sorry but then I’m not going to be of much help. The part number is the one for the model and serial number, which you posted. https://www.partstree.com/models/72...9999999-1978/engine-group-f100-models-7268-1/
S steveleb Member Joined Oct 27, 2013 Threads 8 Messages 28 Sep 23, 2023 / LB 7268 Coil #9 Thanks for your help, but do you agree that it looks like it won't fit. Thanks again
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,769 Sep 23, 2023 / LB 7268 Coil #10 With coils I can’t go by looks, as curvature and bolt hole can have small differences and dictate changes. I go buy part numbers unless I have both in my hands.
