Lazer Z XS Diesel two way fuel (the valve that toggles between left and right fuel tanks) shutoff valve replacement
shoughtonh
  • / Lazer Z XS Diesel two way fuel (the valve that toggles between left and right fuel tanks) shutoff valve replacement
Anyone ever replace one? Will I need to bleed the fuel system after its done? Thanks
Auto Doc's
Choke the fuel lines with the appropriate tools near the valve, replace the valve and then take the line chokes off and let it set for a minute. After that, you should be good to start and run. The idea is to not bleed the entire lines out while replacing the valve.
shoughtonh
Thanks. Thats what I was hoping for.
