Gorrillasnot
- Jun 17, 2015
- 23
hello,
I have a 52" Lazer Z HP model LHP5220KC.
The manual calls for part number 513211 hydro filter which is 10 micron, parts tree shows eXmark 109-4180 which is a 25 micron filter both filters mentioned are close to $30.
I watched a video on youtube showing how to change the hydro fluid n filter on a lazer z https://www.youtube.com/watch?v=tlPM7hhGylY and the guy uses a napa part# 1374 (same as wix 51374?) filter which is 25 micron and is like $8
I called the dealer and they said not to use anything except a Exmark brand 10 micron filter ($35 from them and $19 per quart for 15W-50 synthetic oil).
My question is would the napa/wix filter be ok to use or maybe a 10 micron Stens or should I pay up and get the exmark brand filter? ?
Also would following the youtube video be a ok procedure for changing the fluid? (I don't understand the need to loosen the freewheel valves)
And for the oil filter for a Kohler CV640 20HP Khohler part # 12 050 01S what would be a good alternative that maybe a local walmart or auto parts store might carry?
thanks
thanks
