Lazer Z Deck Adjustment
DanAyo
I wanted to check the deck adjustments on my LazerZ S series.I want to try a 1/4” rise on the rear of the deck. But one blade tip is 3 3/8” and the other side is 3 1/8”. Deck looks fine, blades not bent, but I am unable to make the adjustment.
I followed the instructions in this link.
Exmark and Toro are similar.
I used to own a Toro.
Here's what I would do.
Cut yourself four wood blocks.
Cut 2 at 2 5/8"
Cut 2 at 2 7/8"
You want to place these blocks under the edge of the deck in line with the wheels.
Put the 2 shorter ones up front and the 2 longer ones in the rear.
Make sure that your mowing height selection is at 2 3/4"
Adjust your deck to where the blocks slide in and out with ease. Like using a feeler gauge.
Thank You, so for a 3” height I’d cut 2 @ 3 1/8nand 2 @ 3 3/8. But I think the problem is that when I lift one side of the back, the other side rises also. It is a 48” deck.
Update, are your measurements taking into consideration that the blades are recessed 1/2” ABOVE the bottom of the deck?
Yeah, I edited my post. Usually, the blade tips are 1/8" higher than the bottom of the deck.
So, you need to determine the difference on your particular mower. Deduct that difference when cutting your blocks.
Use a tape measure, correct tire pressure, level concrete. Don’t overthink it and get it to within 1/4” all the way around level.
Personally, I don't like the rear being 1/4" higher than the front. I don't get a good clean cut with the deck set like that. I get a cleaner cut with the rear 1/8" higher.
@Tiger Small Engine said level all around. It's worth trying.
Think of it this way. Most push mowers can only be set to mow at level all around. Some people scoff at setting zero turn decks like that. Also, take a look at lawn tractors, the decks are usually set up level all around.
Play around with it. See which setup works best for your particular mower.
I think I may have to settle for good enough is good enough. I can get 3 points set but the last adjustment at the rear needs to go down, but loosening the adjustment doesn’t lower the deck only puts slack in the chain.
I appreciate your help.
Check all of the chain mounting points.
Something is in a bind.
Also, make sure the chains are all the same length.
Everything looks good to me. The remaining adjusting chain goes slack amd will not allow the deck to lower anymore.
