AnthemBassMan
-I had the 10201, which used the same V-Series engine. It must have had pretty high compression. If I tried starting it on the compression stroke, it would pull the front of the mower right off the ground just about every single time. If I eased the engine past the compression, it would start just fine without lifting the front up. Those V-Series engines are unrefined, yet torquey/powerful beasts! Mine would chew up anything I pushed it through.
L8R,
Matt
L8R,
Matt
