Tristan2021
- May 30, 2013
- 10
- 25
need advise in one day or this good lawnboy goes to the curb
Why not just buy a set of rings for about 20 dollars and 2 oils seal for under 10 dollars.The low compression is the likely problem. You can buy a piston for a D-series engine on eBay but they're a bit pricey, IMO. And that alone might not be enough.
If I were you I'd keep the mower and keep my eyes open for deals on other LBs with D-series engines. Then you can cross parts. I've made several good mowers that way.
Why throw it out? It has lots of good parts. If you don't have the space to keep it you could take it apart and sell the parts on eBay (I'll bet you could do pretty well but it does take time.)
I imagine you're probably frustrated about this but throwing it away is such a waste. :confused2:
In case you need specific instructions for working on the engine here's a link to a great online resource:
LAWN-BOY SERVICE MANUAL 1950-88 (FORM 492-4608, INTERNET REVISION)
Bear in mind, the best thing you can do is hold onto the mower and keep looking for others in its class. I think Iowa is a good place for LB hunting -- better than Georgia. :laughing:
ihave put to much time and money in this lawnboy 8251 if anybody wants it,it has a new coil freshly cleaned carb and newly primed deck,i am in iowa just message me and by the way it is free i will cut my losses
