Lawnboy 22260 project
Ejd148
Hey guys,
So this is my first project mower. I picked this up cheap and wanted to bring it back to its original glory. It's a working machine with good compression, just shows a lot of age from being left outside for a long time. Most everything is cosmetic and cleaning but never the less, I'm excised for the paint to cure so I can reassemble and fire up my first duraforce. I'll post more pics when it's all together.
That's the Holy Grail of Lawnboys (at least for me),,,looks good.
Jeff
Great job so far! That's one thing that irks the crap out of me. That mower is far from being a cheap, $150 Wal-Mart special. But someone just leaves that thing sit outside to waste away. Way to breathe life back into it!!
L8R,
Matt
A trick I use when painting wheels is to mask off the tire with cheap grease. when paint is fully dry and cured wipe off with gasoline.Oh did I recomend using gas as a cleaning solvent?I meant to say brake cleaner which has a lower flash point and smells better
All I need now are decals and a trailing guard. She's a one pull wonder and a welcomed addition to the stable. Can't wait to use it.
Very nice, good work. Looks like the rear bagger is an S21ZPN?
One safety tip, though. Don't store your propane tank in the garage or anywhere else inside. Very dangerous.
