intruder1500
Went to start subject and pull cord was normal on first pull but no start. Pulled cord a second time and there was no tension on the cord. First thought was that the metal hooks that grab the starter cup were damaged or that the cup itself was worn. Removed both but no apparent damage. Replaced the recoil shroud and the starter cup with a known good used unit and no change. When you spin the cutting blade by hand the recoil does turn and some pressure is required to turn it so I don't think the blade shaft is broken nor is there a loss of engine compression. I'm at a loss. Any thoughts would be appreciated.
