intruder1500
- May 13, 2020
- 14
- 107
So mower has been running fine since the coil was replaced. Cutting grass and stopped for 5 minutes. Went to restart and no go. Pulled plug and it was dry and good color. Changed plug with a used one and it started on the first pull. Wondering if the bail control cable needs adjustment as I don't see any other reason for it not to start just because I changed the plug. ( I did release the bail while changing the plug ) There is some slack in the cable before it starts to engage. Anyone have the proper procedure to adjust the cable or any other ideas. Thanks in advance.
