exotion
- Jun 24, 2012
- 66
- 3,444
Yeah I would suggest a bike shop, but I don't know if they have any "stick-on lights".
Zip ties and duct tape.....
Do you know of any kits to do that that are pretty easy to connect because I am a beginner at the electronic conecting
Here's an example of what I called a piggyback spade terminal. This would be a great way for you to get power from your headlight switch to your lights, if your switch uses spade connectors.
PIGGYBACK CONNECTOR 16-14GA PVC BLUE 100PK
I think I have found what looking for. It is flashing strobes with controller I can hook up to battery. So if it will work I might get the piggy backs so when I turn on headlights I can turn on the controller for the lights. I will put the wires strait to the battery if having them on doesn't run down the battery. Do you know if they will. Here's the link.
4x 3 LED R/B Police Car Truck Grille Flash Strobe Light A163r
You can hook them directly to the battery, but I would advise you to connect them to the headlight circuit. That way, you know they are only on when the headlights are on, and there is no way to leave them on after you've shut the tractor off. That looks like a neat set of flashers for the price. Let us know what the final price is after shipping and how well they work.
Finally price is 25 dollars. Ordering them tonight
