Fasteners came loose and the pushrod got bent. The fix is not too hard todo....
Fish Lawn Pro Joined Aug 2, 2013 Threads 11 Messages 5,145 May 21, 2014 / Lawn Tractor B&S 19.5hp died mid mow... wont start. #11 Fasteners came loose and the pushrod got bent. The fix is not too hard todo....
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 63 Messages 15,820 May 21, 2014 / Lawn Tractor B&S 19.5hp died mid mow... wont start. #12 Yes after you said oil level was fine i figured it was going to be a valve issue. Post all your engine model numbers and I'll try to find you a service manual to help you out.
