Export thread
lawn rollers and other questions
#1
R
robert
Is there a definitive source for tips on planting new lawns?, which fertilizers, seed-roll/don't roll, cover with straw, fabric or not?
#2
K
KennyV
well robert... I suspect you would have to factor in your location.... "wrong place,wrong time" & hope you don't get the wrong seed in the wrong soil type..... :smile:KennyV
#3
L
LandN
how about if you try googling YOUR state extention horticulture,..example......google illinois extention-horticulture then hit the lawn section good luck
#4
S
somoolive
Planting a lawn can be a daunting task! However, if you take it a step at a time, you can get the job done without feeling overwhelmed. Check your soil, Decide what kind of grass to grow, Decide whether to use seed, sod or plugs and plan your Watering needs as required based on seed, sod and plugs.
