Hi there,
I've started to notice my lawn mower start to surge when I'm using it. I cleaned out the carb a few months back and have a new air filter in it.
Any idea as to what might be the cause? Should I put in a new carb? I think maybe there is gunk in the fuel tank which impedes gas flow. I thought maybe when winter comes to let the gas burn off, then spray and wash the inside of the tank with water and then let it dry since it won't be used for a few months. Not sure if that would do the trick.
I've attached an image of my lawn mower. The model # is 917.385121.
Thanks!
Thanks!
