lawn mower died and won't crank
alabama402016
Why lawn mower started great but died 5 mintues later and will not start.Its a craftsman with briggs engine.I think its a 2016 model.It quit running all a sudden as if stopped getting fuel.
why bad/? it cranked and i ran it for under 10 minutes and it all a sudden died and wont crank back up.
Goin to need more information , if it spins over it's Cranking but wont start,
If it's spinning over give it a shot of starting fluid in the air cleaner , if it hits and trys to run , it's a fuel problem if not it's ignition
Well if see you post it crunked instead cranked.
Crunked definition: excited or intoxicated
So it might of had one too many drinks.:p
As posted we more details of the problem. And need the equipment model number along the engine model and type (spec) code.
It crunked?(you say)
That could be bad.
Just have let it sober up...Boy bad word spelling can you on the wrong path quickly. And spell checker can't help with the wrong word is spelled correctly.
