lawn mower died and won't crank
alabama402016
Why lawn mower started great but died 5 mintues later and will not start.Its a craftsman with briggs engine.I think its a 2016 model.It quit running all a sudden as if stopped getting fuel.
Goin to need more information , if it spins over it's Cranking but wont start,
If it's spinning over give it a shot of starting fluid in the air cleaner , if it hits and trys to run , it's a fuel problem if not it's ignition
why bad/? it cranked and i ran it for under 10 minutes and it all a sudden died and wont crank back up.
Well if see you post it crunked instead cranked.
Crunked definition: excited or intoxicated
So it might of had one too many drinks.:p
As posted we more details of the problem. And need the equipment model number along the engine model and type (spec) code.
