Tunar
Hello,
New member here. I have a Lawn Boy S21ZSR that I just can't seem to get running. This mower stopped working a couple years ago. I tried to clean the carb up then but the cable that hold the flywheel brake was stuck and I didn't have more time to spend on it. Fast forward to this last winter and I dragged it back out to get it running.
First order, I disassembled the carb and cleaned it all out again, it was just as clean as I left it. I drained out the little bit of old gas. Next I ordered a replacement cable from Ebay to fix the frozen engine brake cable. It must not have been for this model because it was a bit too long. I cut a piece of pipe to space it out to the correct length. The engine ignition cut off switch still works just fine. Air cleaner and filter are clean. The gas tank is clean and has fresh gas in it. The gas tank filter screen looked clean. Gas drain out of the tank well. I disassembled cleaned and reassembled the gas tank fuel cut off. It has new fuel line and a new fuel filter. I blew air through the fuel line and filter with no restriction. The gas will drain out of the gas tank and out the line at the carb connection point ok. I loosened the float bowl bolt today and gas started to drip out. It appears to me that gas is getting to the carburetor ok.
I have disassembled and cleaned out the carb a few time now, hoping that would fix this, but it's all clean. I sprayed carb cleaner through all the passages, removed the air mixture screw and float needle when I did that. The only thing I didn't remove was the float needle seat, but the carb cleaner blasted right through the carb fuel intake just fine. Choke and throttle cable seems to be working correctly opening and closing the butterfly valves like it should. I've tried to get this mower to run with the air mixture screw at 1.5 turns out, .5 turns out and 3 turns out... nothing works.
Pulling the starter cord ignites a spark in the spark plug, I checked. This mower will start and run on starter fluid (I know it's not he best to use on 2 strokes but this mowers old and if it won't start, it will be scrapped) so I'm assuming that means that the spark is good and it's a fuel issue. Any thoughts?
Is there anything you can suggest I check? My last idea was to remove the float bowl and see if gas drained out. I did that this morning and it seems to be getting gas to the float bowl.
Thank you for any advice.
