Lawn-Boy Model 4263 Won't Start
Phototone
"Some" lawnboys just had a choke function on the carb. Earliest ones you choked by pulling up on the on-off switch. There were models in the 1980's that had the choke activated by pushing the throttle lever past "fast".
robinb66
Chances are that if it has a throttle then photone is right. Just push the throttle as far past the high speed setting as you can get it
