I just got a free lawn boy model 10304. It leaks gas from the air filter box.
The float was cracked into, so I thought that was the problem. I cleaned
the screen filter and sprayed everything with carb cleaner. I replaced the
float and put in a new needle and new seat. Put it back together and it still
leaks dripping out of the filter box. It won't start either. It will fire after priming
but stop after about one or two seconds.
do I need to adjust the float some way? Can anyone out there help me out?
Thank You.
Thank You.
