mmahoney626
- Aug 25, 2015
- 15
Greetings everyone, I have a John Deere LA145 that has run and mowed flawless since I acquired it. This week when I mowed, it has developed a strange condition I can't quite confirm the cause. I start the mower, brake pedal depressed. When I release the brake pedal, there is a noise coming from, as best I can tell, underneath the engine. When I depress the brake pedal, the noise goes away. The noise sounds very similar to when a blade spindle bearing is bad and the spindle needs to be replaced. The mower is not in motion, blades are not engaged. Based on the symptoms, my best guess is that there is an issue with the PTO, and I was going to replace. Can anyone confirm the diagnosis?
Thanks
Thanks
