LA 115 deck belt guides
It does that when you release the PTO lever and the belt flops around for a few seconds and eventually wears thru.
Bill and CC are correct. I have never seen it happen cause I have not seen a guard on the right side of the deck.
I just got on here had to make 2 house calls and go to my buddy's machine shop to use his mill to take a broken bolt out.
I adjusted the breaks so that the belt only turns for about a second after the blades are turned off, not long after I bought it. Is it just gonna be one of those things where I'll have to replace the guards every so often?
