I have a JD L108 lawn tractor.
Until recently it has worked perfectly. This problem started occurring suddenly not gradually.
It bogs down in heavy grass and usually dies.
Cranking the motor will not restart the engine.
Turn the ignition all the way off, the cranking the motor will restart the engine immediately.
Then it will run fine until bogged down again.
Visual inspection revealed broken wire harness that is anchored to the frame directly below the oil drain.
I have not figured out where the wires are supposed to attach.
Also, while suspicious, I cannot be 100% certain that the wires are the cause of the problem.
Thanks in advance for any advice.
Jim
Jim
