I have a L100 in which the 5 speed transmission is making a loud clanging noise when only in 2nd gear. I am assuming something in side the transmission that is dedicated to only the 2nd gear is going bad. All the other gear speeds do not make a noise. I am avoiding using the 2nd gear because it may damage the other gear speeds. I now mainly use 1st and 3rd gear. My question is will the other gears likely be affected by the this defective 2nd gear?
jemret
jemret
