K Kuler64 Forum Newbie Joined Sep 20, 2016 Messages 1 Sep 20, 2016 #1 exmark 27hp kohler pings under load and starts missing after a time then picks back up 20 minutes or so later
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 11,981 Sep 20, 2016 #2 Get us the model and spec number off of the engine tag so we can see what configuration of engine you have.
RDA.Lawns Well-Known Member Joined Jul 24, 2016 Messages 529 Sep 20, 2016 #3 Kuler64 said: exmark 27hp kohler pings under load and starts missing after a time then picks back up 20 minutes or so later Click to expand... First thought is bad gas. Sounds like what is referred to as labor knock . could be a few different causes . First replace the gas with good fresh gas. Check for results .No improvement your carb could be to lean .
