Kuler64
Kuler64
exmark 27hp kohler pings under load and starts missing after a time then picks back up 20 minutes or so later
Get us the model and spec number off of the engine tag so we can see what configuration of engine you have.
RDA.Lawns
First thought is bad gas. Sounds like what is referred to as labor knock . could be a few different causes . First replace the gas with good fresh gas. Check for results .No improvement your carb could be to lean .
