oldntired55
just a quick note here, i have seen several craftsman and jd mower decks fitted with grease fittings at top of spindles. yet on disassembly, found sealed spindle bearings, both sides not 1. my thought always was... how can the grease get into the bearings?? i dont think it was intended to force its way past the innermost seals///??// i had an old craftsman 42 inch , i put new bearings in and popped out the inside seals... i ran that deck for 12 yrs, on the same set of bearings... just sayinIt should be either a Z421-KWT-3 OR Z421-KWTNC with a Kawasaki FS730V-AS17 engine 24hp.
The deck would be a RCK60P-400Z.
Just because there is only a few hours on a bearing doesn't mean they can't have problems. I one mower here that was constantly snapping belt. I had the customer pay a close attention as when it was happening. With that info I finally found one bearing that had what appeared to be minor catch during testing. It was enough to snap the belts on start up it happen to have been resting in that spot. Can even be rust in the bearings.
And some bearings have poor lube installed in them from the bearing factory which causes early failures. This deck uses 6205-RST bearings [6205-ZZ]. There should be grease zerks on the spindles but I see none in the images of the spindle housings so it is highly you ever greased the bearings.
From your further descriptions of the problem it is leaning to a poor clutch engagement problem and might be that the FT-LB torque of the clutch is too low for the deck load. Can even be that the grease in the bearings is hardening.
Or you can have grass and other crap like baling twine or plastic bags wedged between the blades and the spindle housings or between the spindle shafts and the bearings in the lower spindle housings.
So it can be a multitude of problems combined.
