I had previously posted about water in gas but it might be oil in gas (see previous post with pictures).
I drained the gas out, just opened the carb today & dumped the gas with oil or water in it out (see past picture).
How to remove the main jet for cleaning (pic #5)? Since it does not have the grove for the screw driver.
I had to repair some wiring because it's too short & came apart or broke off.
I bought the carb on AMZ 2 yrs ago (pic #1 - old one on L, new one on R) but didn't use it because the new one does not have 2 connections (see pic #1 with 2 circles, could I still use the new one without these 2 outlets?) but the repair guy use the bottom part of the new one with the old carb (I removed the pin on the old one, pic #6 because one of the youtube video said I can remove it if it's malfunction. I don't know it's malfunction or not).
I also just realize that the carb (& the filter box, pic #3 & 4) is smaller than the old hole & someone use bolt on the right side which is too short. So I ordered the steel rod on AMZ & use it on the right side & add one to the original (right) hole so it's more stable because the rod in the middle does not attached to anything.
After I opened the carb & drained the gas, it still won't start, just crank.
What else should I do or investigate?
I'm new to small engine & learn some from YouTube.
I'm also female who does not have background in the repair, mechanical, etc.
I paid enough money to have my equipment repair.
I need to learn all these since the thieves will keep sabotage my equipment every year, many times a year.
They sabotage my A/C system, my riders, my pressure washers, my robotic mower, etc.
They also stole a lot of my stuff & it still going on.
It seems like they are pretty smart more than many intelligent person because I never caught them on tape, alarm never go off.
They can beat or by pass the security cameras (lots of cameras), alarm system with motion sensors, contact sensors, smart locks, etc.
I need help in many ways I can.
