Kubota T1400 no spark
Breton Lion
Hi .. Well after checking the coil .. cables plug etc .. there is still no spark ..
Could it be the flywheel ..
Or is there another problem we should look at ..
Thanks ..
Auto Doc's
You have an odd one when it comes to riders.
Remove the top engine cover and disconnect the single wire coming from the harness, that is a "kill wire" that is meant to ground the coil to shut the engine off.
Recheck for ignition fire. If still no fire, bad coil. If it has fire, it may be an issue with the key switch a safety switch or the wiring.
If a coil failure is the issue, this Kubota has an Onan engine and coils are not cheap, but there is a cheaper solution. Check out the following video by Teryll Fixes All around the 6:10-minute mark.
Breton Lion
Hi ..
We have checked the coils .. and rechecked them all working OK ..We even bought new ones as advised .. very very faint spark from one .. not enough to start the engine ..even using easy start ..
