Kubota l2850
amalfikid
Just bought a kubota l2850 4x4 shutle shift trans. Would like to know what year this is and also what kind of hydraulic oil do i put in filler located on floor beneath the steering wheel.
Thanks
Thats a very handy sized gear drive 34 HP Kubota...
It was built from 1985 to 1990.
Do you have the front end loader, mid mower or back hoe with it?
The trans/hydraulic fluid should be Kubota UDT... I would get TSC premium UDT... it's 1/2 the price.
Power steering was optional on that model, If you have it it has a separate pump.
You can find a lot of the specs at this site: TractorData.com Kubota L2850 tractor information
Check with your local Kubota dealer, he can look up the production date with the serial # if you need the exact year.
Fun little tractor... Got to love a Kubota... :smile::smile:KennyV
PS... welcome to this great Forum... a very very good Kubota forum is tractorbynet.com ... it is by far the best tractor forum to be found, and it belongs to the same fella that set this forum up...
