Born2Mow
The EPA has made carb, fuel tank AND engine breathers so complex that it's a wonder they can function at all. Certainly, most of it is counter to what the engine really wants. When 95% of the posts on a small engine forum read "my engine doesn't run right" or similar, you know something is amiss.Excessive idling WILL cause fuel vapors to build in the crankcase over time. Perfectly normal. Engine isn't designed to idle a lot. Full throttle/speed is what it's designed for.
