- May 6, 2010
- Threads
- 51
- 11,431
The original setup operates as a high vacuum system, but didn't allow enough air exchange to prevent too much vacuum from building in the fuel tank. causing a plugged gas cap vent effect. The new line going to the air cleaner housing basically creates an air leak within the evap system without venting to the atmosphere.So the defective piece is the plastic cap?
