Bildo McCreedy
- Jul 8, 2026
- 2
Ok so problem started after I mowed a bit of wet grass. I started losing power at first when blades were on or off. It kind of sounds like surging? Maybe. I replaced the carburetor, fuel pump, and spark plugs. Then it started only losing power when the blades are on. I just replaced the govenor spring and it sounded different. I thought it was better because when I had the blades in it cut slightly better. Now it was dusk so slightly dark and when I got off of the mower the exhaust was literally glowing. Like the whole thing. Im think maybe I either installed the carb wrong and its losing air or fuel. Or I need to adjust the govenor. Any help will be greatly appreciated.
