T Talltree Member Joined May 6, 2023 Messages 15 Feb 9, 2024 #1 Sometimes the engine will start as soon as you turn the key. Other times you must turn engine by hand until it won't turn any further, then turn key and it will start. Already reset valves. Runs fine. just start problem
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,035 Feb 9, 2024 #2 Is there a pattern to the no start. Like starts fine cold, but won't crank without turning the flywheel by hand hot.
T Talltree Member Joined May 6, 2023 Messages 15 Feb 9, 2024 #3 Yes, it happens like you said, starts when cold but have to turn by hand when hot.
T Talltree Member Joined May 6, 2023 Messages 15 Feb 9, 2024 #4 Talltree said: Yes, it happens like you said, starts when cold but have to turn by hand when hot. Click to expand... definitely a pattern.
T Talltree Member Joined May 6, 2023 Messages 15 Feb 9, 2024 #5 definitely a pattern, Starts when clold, must turn by hand when hot.
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,035 Feb 9, 2024 #6 I would be thinking either valve clearances even though you said you checked them or sticky compression release on the camshaft
T Talltree Member Joined May 6, 2023 Messages 15 Feb 10, 2024 #7 is there a simple fix for compression release. don't have a clue where or how.
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,547 Location Pluto Feb 10, 2024 #8 Or it can be simply a worn out starter. I replaced quite a few of these starter that Bendix side bushing are worn and binding in certain positions. Also note that the 32 010 07-S camshaft does not have an ACR.
