sgkent
- Sep 27, 2017
- 35
- 1,983
if you are saying that the side that glows struggles, then I would suggest looking at the valve clearances, pushrods, etc.. Make sure that nothing is mechanically out of whack with the valves. If spraying a little flammable carb cleaner around the intake manifold, head, places where an intake leak could occur didn't change anything, it may not be a mixture issue with only one carb. That said, best way to look for leaks is using a smoke test. Every mechanic should have one or make one. All it takes is a bicycle pump, an old paint can, some old rags or a cigar, a barb and a hose to make one up. I bought a premade one for about $70 that has a regulator on it so I can hook the compressor up to it. Makes tracking down vacuum leaks really quick and easy.
